We just updated both Sewergem and OpenRoads to versions U3-10.03.00.78 and R2 - U8 - 10.08.01.33. Before we could open SGs models in ORD through drainage and utilities "import hydraulic model", but now it shows a compatibility error:
Is there a place where we can see what versions work with each other?
Hi Pedro Serra,
This Wiki article contains a compatibility chart between OpenRoads products and OpenFlows products.- Platform Compatibility Chart – Civil Products – OpenFlows Products.
Also, this Wiki article explains a model's forward/backward compatibility. The latest version of OpenRoads Designer works with SewerGEMS 10.02, which would explain why you get that error when trying to open the model saved in SewerGEMS 10.03 which explains why you got the message - Model backward / forward compatibility.
And, OpenRoads Designer is planning to roll out 10.09 by the end of next week and it is compatible with our OpenFlows 10.03 products.
Please let me know if this does not answer your question.
Thanks,Larry
Answer Verified By: Pedro Serra
