Explicate (SWMM Solvers)
Hello
I am trying to run a model of a Storm drainage system (Catch basins, pipes, and perforated pipes) using the Explicit Solver SWMM, after running the model I have got a user notification :
node known flow and additional flow are ignored by the solver
And the flow inside all pipes is zero, what should i do??
Iam using Sewer GEMS CONNECT edition.
