How to control PRV to maintain a constant target pressure at a node?
I want to set the PRV downstream control so that it maintains for example 10 mH at my target point all the time. Means the PRV downstream pressure will fluctuate to maintain 10mH at the target point. It is not a fixed outlet PRV.
How can I set such PRV controls?
