I have the pump target flow set at 1000 gpm and FCV set as active with 500 gpm for the initial flow. Not sure why there is no flow coming out of the pump when running the model. I am trying to understand what could cause the issue? The model is balanced but I have a warning message indicating FCV cannot deliver flow.
Hello Michael,
Are there any user notifications related to the pump? This link may have some information that can be useful.
Are there controls on the pump? Where is the FCV relative to the pump? It may be useful to see a copy of the model files as well.
Scott
Hi Scott,
the user notification states: VSPB cannot deliver flow or head but nothing about the pump. I have the model uploaded. it is Scenarios -> Fall Operation-> Purple Trace -Fall. Thank you for your help and time in advance.
Could you let me know what elements you are looking at? There are a number of VSPBs and FCVs in the model.
I am looking at Brkly Well - VSPB-26 and FCV 34. Not sure why no flow comes out of the VSPB.
The VSPB is initially off. If you set the VSPB to be initially on, there will be flow through the VSPB and the FCV. It looks like there is no control on the VSPB, so if the VSPB is initially off, it will stay off through the run. You can add controls, but it can be a little tricky with variable speed pumps. There is information in the Help documentation about this.
The FCV is initially set as Inactive, which means that the FCV is fully open through the run. Given the placement of the FCV, this may be as expected. Otherwise you have a flow of 1000 gpm and immediately drop that to 500 gpm.
