WaterCAD 10.03.01.08 64-bit
There was a previous discussion of this problem back in July 2018, but that thread has been locked.
I'm trying to customize the graph (which is automatically included at the end of the report ("Calculation Summary" window, click on "Report" icon). I cannot find any way to modify the look of the graph.
Also, it does not show the legend at all. I've had the "legend not showing" problem on other graphs, but was able to work around it by shortening the legend descriptions. However, it seems that there is no way to modify the Report graph at all.
Please tell me what I'm doing wrong.
TIA
As a followup question, I would like to save a "Calculation Summary" graph as a "Named Graph" so that I can include it in my custom report.
I can save other graphs as "Named Graphs", but I have not found a way to save a Calculation Summary graph as a Named Graph.
Hello Gary,
Currently calculation summary graphs can only be saved as pdf and not as a named graph which you can include in custom report.
However as a workaround you can include this calculation summary graph pdf into your final custom report pdf externally using adobe tools.
We are logging a feature request (reference number #479129) for this to consider saving of calculation summary graphs which can then be included in custom reports.
Sushma Choure
Bentley Technical Suppport
Thank you for the quick response.
Yes, I'm aware that the graphs can be saved as pdf's, then imported into other applications.
It would be a huge improvement if the feature request is implemented.
This feature request information is included in custom report wiki to notify other users that such enhancement is there in place to be able to include calculation summary graphs into custom reports.
Creating Custom Reports
