"Demand Distribution (Start) (%)" field
Watercad 10.03.01.08 64-bit
In the "Demand" Alternative, "Customer Meters" tab, there is a column labeled "Demand Distribution (Start) (%)".
What does this do? I cannot find anything in Help that describes its purpose or what it does.
  • Hello Gary,
    What you can do with this field will depend on what the customer meter is associated with. If the customer meter is associated with a junction, the Demand Distribution (Start) field will not be editable. This is because all of the demand will be associated with the junction. If the customer meter is associated with a junction, this field can be ignored.
    If the customer meter is associated with a pipe using a lateral and tap, you can define how the demand is distributed between two junctions. The default for Demand Distribution (Start) is 50%. You can enter another value and the field for Demand Distribution (Stop) will update automatically.
    I have updated this link with information related to this.
    Scott
    Answer Verified By: Jesse Dringoli
  • Thanks!  I believe I understand it now.
    If I understand correctly, if a Customer Meter is assigned to a junction then the Demand Distribution filed is meaningless.
  • Hello Gary,
    Yes that is right. It only apply if the customer meter is associated with a pipe, not a junction.
    Scott
    Answer Verified By: Gary Adams
Reply Children
