Watercad 10.03.01.08 64-bit
I've got several elements (scattered throughout the network) that I want to graph data for. I've got the elements grouped into a Selection Set.
The only way I've found to get to the "Graphs" option is to activate the Selection Set, then "Select in Drawing", then zoom into one of the elements, right-click and select "Graph".
It seems to me that, when the Selection Set is highlighted there should be a "Graph" selection available on the right-click menu.
Am I missing something? It seems like a trivial matter to zoom into an element, right-click and select "Graph", but that's a lot of (IMO) unnecessary zooming and clicking.
Hi Gary,
Network Navigator and Quick Graph may be a good option for you.
On the Ribbon, navigate to the View tab, click "Quick Graph" and then click "Navigator" to open those windows.
The Quick Graph window has a "Graph" button on it as well - click that if you want to open a dedicated graph window for each element as you progress.
Rob.
Network Navigator:
Quick Graph
Thanks! It looks like that method will work fine - no zooming in/out required!
