Watercad 10.03.01.08 64--bit
Can the Target Head of a VSPB be set via an Alternative? I'm trying to test various target heads for an new VSPB in an existing system.
Sorry - found the answer: "Yes" - use the "Physical" Alternative
Hello Gary,
You can model separate scenarios and alternatives to compare the results for different target heads of VSPB to help you decide one, please go through below technotes if not already.
Scenario and Alternative Management
Annotate difference between two scenarios or multiple scenarios at the same time
Sushma Choure
Bentley Technical Suppport
