Demand Allocation
I have a billing meter database which compromises properties with two or three kinds of consumption (e.g., residential, commercial and irrigation for an individual property). I imported these duplicate demands by individual LoadBulider run through Nearest Node method. Now, I wonder what is the best approach to be ensure about correct allocation of duplicate demands to those properties in WaterGEMS (connection Edition)?
Ryan
  • Hello Ryan,
    Please see below link that shall guide you to check demands allocated after Loadbuilder run.
    How to view demand or load allocation after a Loadbuilder run?
    Sushma Choure
    Bentley Technical Suppport
  • Hi Sushma,
    Thanks for your quick response. I have applied another method. I used the Demand Control Center and copy the Label of all Junctions and paste them in an Excel file. Then I sorted them ascending and by writing the IF function, I have found the nodes that have multiple demands in the network.
    However, currently I found an amazing issue on demand allocation procedure that some of the demands have been assigned to the nodes directly at the downstream/ or upstream of a tank (nearest node in the shortest distance) which I believe that should not be correct. How can I verify the model for those demands and why this issue happen? I should mention that I used the Thiessen Polygons and LoadBuilder ,nearest node method for demand allocation.
    Ryan
  • Hello Ryan,
    If you are using the Nearest Node method, you would choose a node layer. For instance, if you want to apply this to junctions, you can choose "Junctions\All Elements." If you do this, you should not see demands applied to tanks.
    How were the Thiessen Polygons applied? The Nearest Node method uses a node layer by way of the either all of a given element (like junctioins) or a selection set within a node layer. The usage layer is typically your demand data from GIS.
    You also mention using Excel. You can use an Excel file to add demand data using ModelBuilder. The steps to do this can be found in this link.
    Scott
Reply
  • Hello Ryan,
    Scott
