Drainage and Utilities-Catalogue conduit varying thickness
Hi, Im using OpenRoads Designer CONNECT Edition - 2020 Release 3 Cc
Is it possible to create conduit pipe with varying thicknesses?
A 2 barrel pipe is connected to a headwall with 2 openings.
The thicknesses don't align, is it possible to modify this in the conduit catalogue
i.e. outter thickness = 12cm
inner thickness = 27.25cm
