Hey, how i can attach isolation valves to the pipe? i put accidentally put sign do not prompt again.
Hello Ville,
There is a tool called attach isolation valves to pipes which you can use to attach isolated valves to adjacent pipes in batch.
For this to use you need to have isolation valves already imported in the model say via Modelbuilder, more details below.
Assigning isolation valves to pipes in batch
Sushma Choure
Bentley Technical Suppport
Hi Ville,
I'll add a few more things (related to the "do not prompt again" aspect of this):
1) The isolation valve will be attached on layout even if you turn the prompt off (as long as you place it close enough to the pipe).
2) If you want to turn a particular Prompt back on, go to Tools > Options > and click the [Prompts] button.
Best regards,
Rob.
We have captured information about multiple prompts seen while using OpenFlows products below, for future reference of other users.
I chose to not be prompted again – how can I get the prompt back?
