WaterGEMS for ArcMap
Hi there,
I am using WaterGEMS (version 10.03.02.75) for water network modelling, and just recently installed ArcMap (version 10.8.1). Do I still need to install the ‘WaterGEMS for ArcMap’ to be able to build a new model in ArcMap? if so, would you please help me by sending a link for download / installation?
The reason I'm asking is that even though both software versions are seemed to be compatible, I can’t see any WaterGEMS toolbar while using ArcMap ( from: Customize>Toolbar).
Elham,
  • Hello Elham,
    As mentioned by Joeri, ArcMap 10.8.1 version is not tested with WaterGEMS 10.03.02.75, ArcMap 10.8 is certified to work through, as mentioned in below wiki. Though we will check it internally and confirm.
    Platform Compatibility
    Troubleshooting ArcMap / ArcGIS Integration
    Sushma Choure
    Bentley Technical Suppport
    Answer Verified By: Elham Niari
  • Hi Joeri & Sushma,
    Thanks for the advice, I will let you know the result.
    Is it possible to give us more details like how long would that be until the next update for WaterGems' and if ArcMao10.8.1 would be certified by it until then?
     Kind regards,
  • Hello Elham,
    ArcMap 10.8.1 should be supported in next release of WaterGEMS, whenever there is a new update it will be announced here on forum. There is no fixed date as of now.
    Information on product releases, updates, and patches are posted to this blog on BE Communities: http://communities.bentley.com/products/hydraulics___hydrology/b/hydraulics_and_hydrology_blog/default.aspx
    To be automatically notified of updates, you can subscribe to the RSS feed for the blog. When you subscribe to a feed, it is added to the Common Feed List. Updated information from the feed is automatically downloaded to your computer and can be viewed in Internet Explorer and other programs that support RSS feeds, such as Microsoft Outlook.
    To subscribe to the RSS feed, click the "RSS 2.0" link on the right side of the page http://communities.bentley.com/products/hydraulics___hydrology/b/hydraulics_and_hydrology_blog/default.aspx, and then click the "Subscribe to this feed" link.
    Sushma Choure
  • Elham,
    We discussed this further with our developers, who clarified that integration support is added for the "minor" version, which is the "8" in 10.8.1. This means that the current version of WaterGEMS support 10.8.X, including 10.8.1. Nothing additional needs to be done after upgrading your ArcMap to 10.8.1 and you should be able to simply open the WaterGEMS for ArcMap shortcut. Although we did not perform full testing on the exact 10.8.1 version, it is supported and should work. Should you encounter a problem, we will support you.
    I tested this today with WaterGEMS 10.03.02.75 and ArcMap 10.8.1 and it appeared to work properly without any problems.
    I have updated the following articles accordingly:
    ArcMap / ArcGIS compatibility
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
  • Elham,
    Jesse Dringoli
