How do you change the selection (red check mark) on Calculation Options?
How do I move the red check-mark to a different option selection?
Why are some options not able to be deleted?
  • Jesse Ellis,
    You change the selected Calculation Option by clicking on the Pull-down list and selecting the Calculation Options you wish to use.
    This is located in the upper-left corner of your design window.
    This Wiki article should help explain this further.
    The calculation option that is checked is based on the scenario that is active and the ones you cannot delete are the ones used by a scenario.
    This link will take you to the Bentley Hydraulics and Hydrology Modeling YouTube channel to the lesson on Scenario Management in the event that you would like to go back through a refresher course.
    Please let me know if this does not answer your question.
    Thank-you,
    Larry
    Answer Verified By: Jesse Ellis
