Hi, I'm doing the Generic Start Guide - OpenFlows Flood example exercise. But when I run the program, I don't get any information in the model output, I get a blank dialog box, this is also the case with HDF Files and Time Series Files, both files appear empty.
I don't know what I am failing since I am following the step by step that appears in the guide.
I hope you can help me, thanks!
Hello Jorge,
Is it possible for you to share screenshots of what you are seeing? One thing you can ensure on your side is that the input data is correct as per the Generic Start Guide. That can rule out any issues with the modeling.
Have you tried restarting the modeling in a separate workspace? Checked if the DTM is assigned to the current workspace? Check it the modules are properly configured with the time series data files?
Looking at the screenshots can help us understand what is happening.
Yashodhan Joshi
Hello! Here is a photo of what appears to me
Which version of OpenFlows FLOOD are you using? 10.03.00.01? Also, could you please confirm if you downloaded the dataset corresponding to the same version (we have two versions of the Generic Guide).
If so, could you please share the workspace file for further analysis? Please check this article to see how to export the workspace.
Douglas Miranda - Consultant
