FLOWS KEEP CHANGING DIRECTION
Hi everyone
I'm working in this file in which we have two tanks discharging at the same time into a distribution system.  Both tanks are identical and we have an estimated demand plot.  The thing is that the flow between both the tanks are constantly changing.  I know that the HGL is changing but still I can't make it work.  We want the flow to be equal in both discharge pipes.
The goal is to analyze the filling and draining of the tanks, but due to this issue it can't be done since one tank is filling the other.
Here's the file in case I wasn't clear.
Many thanks in advance.
RESERVOIR_DISCHARGE.wtgpkg.zip
