Is there a way to track inspection and maintenance of water asset inspection and maintenance activities using Watergems flextables or is there another Bentley product that can be used with Watergems data for asset management?
Send me an email and I'll tell you about some new things we have coming up. tom.walski@bentley.com
Just as a quick idea here - you can always add your own custom field for elements, to store any desired attribute. For example you could create a new "Condition" User Data Extension (UDX) for pipes, add it to the pipe Flextable and populate it with pipe condition.
If the condition information is updated in an external source, you could connect to it via ModelBuilder and update (sync in) the element fields periodically.
We can also send you information on our upcoming WaterCAP for Risk-Based Pipe Renewal & Capital Planning with OpenFlows WaterCAP. There was a recent webinar that may have been recorded.
