How to split crossing pipes in bulk?
While building the model many pipes are crossing each other and I need to split them at the crossing point using junctions.
    1. Run the "Crossing Pipes" query from Network Navigator to identify all cases
    2. Use the Highlight button to make it easier to see the results while working on subsequent steps
    3. For each cross pipe case where you want the pipes to be connected, insert a junction at the point where they cross (choosing to split the pipe)
    4. Run the batch pipe split tool previously mentioned, to connect the pipes together.
    Jesse Dringoli
    Bentley Systems, Inc.
