how can i hide some pipes from velocity or pressure view ?
like keeping main pipe in view and keep other pipe but not showing them
Could you please elaborate the issue? What do you mean by hiding pipes from velocity or pressure view? Have you color coded pipes?
Did you try making the elements inactive, which will hide them from view but they will be present in the model?
See below wiki's about how to make pipes inactive and hiding them in model view.
Making inactive elements disappear
Active Topology Management
Sushma Choure
Bentley Technical Suppport
If you're referring to annotations (show velocity or pressure annotation only for specific elements), you can create a selection set of just the elements you want to annotate, then select that selection set in the annotation definition. See "Annotating model elements by selection set" in this article: How do I annotate model elements?
i want to hide these pipes i pointed to by red line , i have made selection set but other pipes are unhidden like you see , deleting them will effect in results
You could create a new color coding for pipes, choose the selection set you created, then set the color equal to the background color (white). There is information about this in the following article: How do you add color coding to an element?
Why do you want those pipes to disappear?
