SewerGEMS select series 4 (8.11.04.54)
I am modelling Infiltration trench as a LID for 2 year Return period storm event in catchment. I want to achieve LID performed infiltrated depth of runoff as 40 mm.If you observed calculation summary file in attachment, under LID performance summary ,I am receiving 375.66 mm (14.79 inch ) rainfall as a Total precipitation. And Infiltration loss as 373.63 mm (14.71 inch ) .
But even after changing LID unit area and number of replicate units , there is no change in Infiltration loss as 373.63 mm (14.71 inch ) value.
1.Which parameter I need to change to see the difference ?
2.How would I came to know that my LID is overflowing or not ? (Parameter provided to Infiltration trench is in attachment for your ref.)
3.I want to set 'Occupies full catchment ?' as true but as soon as I run model it gives me error that 'LID are is exceeding sub catchment area ' , hence by default I have to go for False option .How to solve this issue?
Fullscreen 2.With LID calculation summary.txt Download EPA STORM WATER MANAGEMENT MODEL - VERSION 5.0 (Build 5.0.022) Bentley enhanced -------------------------------------------------------------- ********************************************************* NOTE: The summary statistics displayed in this report are based on results found at every computational time step, not just on results from each reporting time step. ********************************************************* **************** Analysis Options **************** Flow Units ............... CFS Process Models: Rainfall/Runoff ........ YES Snowmelt ............... NO Groundwater ............ NO Flow Routing ........... NO Water Quality .......... NO Infiltration Method ...... CURVE_NUMBER Starting Date ............ JAN-01-2021 00:00:00 Ending Date .............. JAN-02-2021 00:00:00 Antecedent Dry Days ...... 0.0 Report Time Step ......... 00:01:00 Wet Time Step ............ 00:15:00 Dry Time Step ............ 01:00:00 ************************** Volume Depth Runoff Quantity Continuity acre-feet inches ************************** --------- ------- Total Precipitation ...... 343.456 14.787 Evaporation Loss ......... 0.000 0.000 Infiltration Loss ........ 52.914 2.278 Surface Runoff ........... 229.470 9.879 Final Surface Storage .... 62.189 2.677 Continuity Error (%) ..... -0.325 ************************** Volume Volume Flow Routing Continuity acre-feet 10^6 gal ************************** --------- --------- Dry Weather Inflow ....... 0.000 0.000 Wet Weather Inflow ....... 226.416 73.781 Groundwater Inflow ....... 0.000 0.000 RDII Inflow .............. 0.000 0.000 External Inflow .......... 18.589 6.058 External Outflow ......... 245.006 79.839 Internal Outflow ......... 0.000 0.000 Storage Losses ........... 0.000 0.000 Initial Stored Volume .... 0.000 0.000 Final Stored Volume ...... 0.000 0.000 Continuity Error (%) ..... 0.000 *************************** Subcatchment Runoff Summary *************************** -------------------------------------------------------------------------------------------------------- Total Total Total Total Total Total Peak Runoff Precip Runon Evap Infil Runoff Runoff Runoff Coeff Subcatchment in in in in in 10^6 gal CFS -------------------------------------------------------------------------------------------------------- PC:19 14.79 0.00 0.00 4.18 9.40 4.60 26.24 0.635 PC:17 14.79 0.00 0.00 10.81 3.85 0.35 2.82 0.260 PC:18 14.79 0.00 0.00 10.79 3.87 0.36 2.84 0.262 PC:8 14.79 0.00 0.00 2.43 10.92 4.79 27.10 0.738 PC:4 14.79 0.00 0.00 1.38 10.79 8.97 44.28 0.730 PC:9 14.79 0.00 0.00 7.95 6.58 0.83 6.21 0.445 PC:10 14.79 0.00 0.00 1.74 10.98 6.97 36.44 0.743 PC:3 14.79 0.00 0.00 3.77 10.17 2.78 17.44 0.688 PC:7 14.79 0.00 0.00 0.21 13.22 3.64 21.70 0.894 PC:12 14.79 0.00 0.00 13.38 1.32 0.10 0.79 0.089 PC:11 14.79 0.00 0.00 5.94 8.40 1.43 9.98 0.568 PC:5 14.79 0.00 0.00 0.21 14.32 0.36 2.84 0.969 PC:13 14.79 0.00 0.00 0.21 14.20 0.62 4.81 0.960 PC:15 14.79 0.00 0.00 3.92 10.06 2.64 16.69 0.680 PC:14 14.79 0.00 0.00 14.12 0.59 0.04 0.33 0.040 PC:6 14.79 0.00 0.00 0.21 9.75 17.07 72.17 0.659 PC:16 14.79 0.00 0.00 1.21 10.60 10.29 49.16 0.717 PC:1 14.79 0.00 0.00 3.40 9.60 3.00 13.88 0.649 PC:2 14.79 0.00 0.00 1.82 9.31 5.94 21.91 0.630 *********************** LID Performance Summary *********************** ------------------------------------------------------------------------------------------------------------------ Total Evap Infil Surface Drain Init. Final Pcnt. Inflow Loss Loss Outflow Outflow Storage Storage Error Subcatchment LID Control in in in in in in in ------------------------------------------------------------------------------------------------------------------ PC:19 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:17 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:18 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:8 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:4 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:9 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:10 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:3 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:12 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:11 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:15 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:14 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:16 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:1 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 PC:2 Infiltration_Trench 14.79 0.00 14.71 0.00 0.00 0.00 0.08 -0.02 Analysis begun on: Thu Apr 01 12:03:07 2021 Analysis ended on: Thu Apr 01 12:03:08 2021 Total elapsed time: 00:00:01
Hello Kushagra,
First and foremost, the version you are currently using SewerGEMS SS4 (08.11.04.54) is not supported anymore. As per our support policy, we have discontinued support for V8i released products. See this link for the support policy: Bentley Desktop Applications Support Policy
Kindly upgrade to the latest CONNECT Edition series SewerGEMS to continue receiving support. See the below articles for upgrading and understanding what's new in the CONNECT Edition series of our products;
Get to know SewerGEMS, CivilStorm, SewerCAD and StormCAD CONNECT Edition
What's New in SewerGEMS, CivilStorm, StormCAD, SewerCAD, and SewerOPS CONNECT Edition Update 3 (version 10.03.03.44)
To upgrade see this article: Downloading OpenFlows | Hydraulics and Hydrology Software
For your primary issue, it seems that we may have to take a look at the model files to check what is happening. However, since the current version is quite far from what you are using, I am sure we will see some changes in results since we are using the latest SWMM engine 5.1.014. As far as overflowing the LID is concerned you can look into this article: Modeling overflow from a Low Impact Development (LID) control
Please upgrade to the latest version so that we can continue supporting.
Yashodhan Joshi
