I hope that this message finds you well. Is there a way to search for a scenario using the Scenario ID? Thank you so much for your help.
Youssef
Hi Youssef,
If you want to go a bit more low level you can go directly to the sqlite file.
Download SQLite Expert Personal (it is a very good tool and the personal version is freeware).
http://www.sqliteexpert.com/
Open the WaterGEMS database e.g. Example5.wtg.sqlite (best to not have the file open in WaterGEMS when you do this)
Use this Query:
SELECT HMIScenario.ScenarioID, HMIScenario.ParentID, HmiModelingElement.LabelFROM HmiScenarioINNER JOIN HmiModelingElement ON HmiScenario.ScenarioID = HmiModelingElement.ElementIDWHERE HmiScenario.IsDeleted = false
Rob
p.s.
I include the ParentID in the result so you can infer the hierarchy to more easily track things down. The scenarios with "(null)" ParentID are base scenarios
Rob,
Wow, this is BRILLIANT! Exactly what I needed, thank you so much!
To close the loop, enhancement # 594754 has been filed for our developers to look into adding a search button to the Scenario manager, to search by scenario label or ID. I have added a note about this to the following wiki article: Managing large number of scenarios
Excellent, thank you so much for your help, Jesse!
