I have a particular sector whose total sewarage load is 2.37 MMLD in total so if I have 800 manholes i want to assign uniform loading to each manhole so 2962L/day to each how do I do that as I tried to assign it's not happening please help.
I have attached the file for your reference.
Hello Rahul,
Lets call this particular sector one zone/sector, so are there multiple sectors in the model or it is only one.
If you have one sector in the model and want to distribute load equally then it would be easy for you to do it.
Use the "Initialize for all elements" option in the Sanitary Load Control Center (SewerGEMS/SewerCAD). This would create a single load entry for every element, with the same load amount, right click and global edit to assign the equal loads here.
If you have multiple sectors or more than one, then you would need to create selection set of the manholes from this one sector and then assign the loads through sanitary control center assuming you don't have GIS data to distribute loads through Loadbuilder.
Here are detailed options, for your reference.
Distributing a lump sum demand or load over a large area
Sushma Choure
Bentley Technical Suppport
