How can I calibrate my model? I have two fire hydrant flow tests? Not exactly sure what to do with that information?
Flow Test Calibration
For two hydrant flow tests,
First make sure static results are good.
Now your static model is good for the static condition
Once you get agreement for all 4 scenarios: Static 1, Static 2, Flowed 1 and Flowed 2, you can feel comfortable using the model in that area over a range of conditions.
In addition to Tom's response above, you can also find help in the below links;
Calibrating a model based on hydrant flow tests
Water Model Calibration Tips
Using Darwin Calibrator
Let me know if these help.
Yashodhan Joshi
