I tried using trex for importing elevations into the model
I am attaching a file for which I have imported from the model builder and then using trex with dxf contour option I imported elevations but elevations which were imported are not correct some were correct but some are way off
I am attaching the file .
please suggest how do I get elevations into the model any other way I need both ground as well as invert
what kind of file my data provider should create as we have tried with many options like shape files also but not happening
Hello Rahul,
The mentioned model files are not attached herewith.
With multiple posts related to importing ground and invert elevations implies that you are having difficulty importing elevations altogether.
You can import ground and invert elevations both using Modelbuilder or use TRex to import ground elevations and MB for invert elevations.
Please upload the TRex file you are importing, dataset to be imported using Modelbuilder, model files etc., zip them before uploading.
Sharing model files.
Preparing GIS data for use in the hydraulics and hydrology products
Sushma Choure
Bentley Technical Suppport
Yes i am having network all made in autocad with 3d polyline with nodes having XYZ coordinates but I am not able to import in sewergems . please help
I have uploaded the file again
You have uploaded a dxf file consisting of polylines, which is the same file you had uploaded for Modelbuilder-creating model issue.
Is it the same file you are using to import elevations using TRex, if yes please note that you need DXF points file or DXF contour file or shapefiles to use TRex, dxf polyline wont help to import elevations using TRex.
Since you are importing DXF polylines files to build the model, below wiki will help you to make sure you are preparing DXF file correctly.
Importing an AutoCAD or MicroStation CAD file using ModelBuilder
If you are importing shapefiles to build the model, it can import the elevations (ground/invert) as well, when shapefile is formatted correctly.
For importing elevations using TRex, you can create the DXF contour file in AutoCAD or DXF point file, where points will contain elevations information or using shapefile also you can import elevations in TRex, there are multiple choices to choose from.
Hello Sushma Ji
yes i have sent multiple posts as I am not able to import what I want. As all the work of adding elevations has been done in Autocad we don't want to do again in sewergems but importing has become very difficult for me.
In the Autocad file name "final recovery delta 2 " There are elevation data at manholes and within pipeline invert elevations for every node is there in Z coordinate. Please suggest what can be done as I used model builder it is not able to bring in invert elevations. I used trex it is showing wrong elevations using dxf contours.
Even in model builder preview I see that many elevations are different from what is visible in autocad.
I have read your wiki article and in the same ways I have entered elevations is still an issue so please look into the file if the file is wrong or I can do something right.
If you can give a small step by step rundown that would be greatly helpful.
I am attaching the main dxf with all the layers
It has GIS integration too if I can integrate that too it would be helpful
Please revert back
