Negative pressure equal to vapor pressure developing at pump suction head readings only found in extreme pressure report
Dear All,
I am working on hammer bentley version 10.3.3.72 and whenever i generate the extreme pressures report, i get negative pressure equal to vapor pressure at the pump suction side. Is this normal, and if so, is there a means to eliminate such negative pressure on the suction side. or this is something that is a glitch in the software and should be disregarded.
Please advise
