SewerGEMS for ArcMap integration
ref: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/212510/opening-a-sewergems-file-in-arcmap/
Hello, again Jesse, regarding the integration between SewerGEMS and ArcMap;
1)My SewerGEMS Bentley version is 10.01.01.04 (64-bit) 5/1/2018, whereas my ArcMap version is 10.8; according to these versions, the integration should normally work, yes?
2)After clicking on "Integrate SewerGEMS with ArcGIS" and waiting for the few lines of code to run, I am opening the ArcMap software. Still, the integration is not showing as none of the SewerGEMS layout tools appears anywhere; I tried running the integration multiple times, restarting the PC, and so on, still, it is not showing...why and how can I fix this? I would appreciate any help regarding this issue because I am writing research regarding the upstream tracing in sewer systems using ArcMap. I really need the integration between these 2 software to work.
Waiting to hear from you,
Kind Regards
Sergio Aoun
  • SewerGEMS 10.01.01.04 version is compatible with ArcMap 10.6.1 version and not 10.8, hence you are not able to integrate these two.
    You can either upgrade SewerGEMS version to latest version 10.03.03.44 which is compatible with ArcMap 10.8.X versions. Or you can downgrade ArcMap version to 10.6.1, continue using same SewerGEMS version and integrate.
    Here is compatibility chart for your reference.
    Platform Compatibility
    Sushma Choure
    Bentley Technical Suppport
  • Hello Sushma, I downgraded the ArcMap version to 10.6.1 as you insisted and then integrated SewerGEMS with ArcGIS, the tools SewerGEMS tools are now appearing inside of ArcMap but this is happening
    When clicking on SewerGEMS Layout bar or any other tool, all the icons and fields are indicating as "Missing" with the block icon?
    how do I fix this? as I have to open a SewerGEMS model inside of ArcMap
    Kind Regards
  • Hi Sergio, it looks like something didn't quite work right with the integration. You may need to restart the computer, delete the "SewerGEMS for ArcMap" shortcut, ensure SewerGEMS and ArcMap are not running, then try running the "integrate SewerGEMS with..." shortcut as Administrator. See more troubleshooting tips here: Troubleshooting ArcMap / ArcGIS Integration
    Once you resolve the issue, you can find more guidance on using SewerGEMS in ArcMap here: SewerGEMS for ArcGIS Pro and SewerGEMS for ArcMap [FAQ]
    Note that version 10.01 of SewerGEMS users older, SELECTserver licensing technology which is being deprecated. It is strongly recommended that you upgrade to version 10.02 or greater which uses the new Subscription Entitlement Services licensing that is still supported. (and use a compatible ArcMap version) See: Important License Update for OpenFlows Users
    Note also that Esri's replacement for ArcMap is ArcGIS Pro, which recent versions of SewerGEMS also integrate with: ArcGIS Pro Integration
    Jesse Dringoli
    Bentley Systems, Inc.
