Hi Jesse
I have still some challenges with exporting/publishing i-model and Map Mobile i-model in HAMMER, and I receive an error every time. Please se the attached screenshot.
Another question is, how to get Bentley CONNECT and Bentley CONNECTIONS Passport on my Android device?
Would you please help me?
Br,
Hasan
Hello Hasan,
Please confirm if there is a "System" folder in your MicroStation Workspace folder (C > Program Data > Bentley > MicroStation V8i >Workspace). If not you might have to re-install MicroStation to see it.
Yashodhan Joshi
Hi Yashodhan
Thanks for your response.
I could not find that folder. But I shoulde notice that I have also the CONNECT edition of MicroStation installed on my pc.
I would make sure that the i-model prerequisite files are installed correctly. It may be worth reinstalling these. There two files are available to download from the Software Downloads page. You should be able to search for the HAMMER installation file and find these as available prerequisites. This link has information on the order of installation for these files.
After installing these prerequisites, try publishing the i-model again.
Scott
Answer Verified By: Hasan Meihami
Hi Scott
Thank you so much for your guide. I will work with our admin following your instructions.
Best regards,
