Cant find the dendritic designer tool in the version 10.03.2.75 also, can i download it separately, i am having an academic license.
Hi Raghavender,
Looks like it should be there for 10.03.02.75 (although there is a mention of a potential problem with that version).
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/48933/how-to-locate-the-dendritic-designer-irrigation-designer-tool-its-user-guide-and-dataset
Rob.
Hello Rob,
I was not able to find the User Guide and the executable in the installation path "C:\Program Files (x86)\Bentley\WaterGEMS".
The version I have is "10.03.02.75"
Mohamad Azzam
Hello Mohamad,
It should be available by default in the installation folder, like in below screenshot.
If not, please try repairing WaterGEMS through control panel, or if required perform clean reinstallation of WaterGEMS using steps mentioned below.
How do I perform a clean uninstall and reinstall of the Hydraulic and Hydrology products?
Sushma Choure
Bentley Technical Suppport
If you can upgrade, I would do that since the issue may not occur in later versions. This link has information on doing this.
Scott
