TREX: All elements in the model fall outside the scope of the DEM
I am using TREX wizard to bring DXF contours created from Autodesk Civil3D surface. I received the following error:
I used the same DXF file as the background, and it overlays with other DXF files as intended without any coordinate adjustments, as mentioned in the other threads.
Any helps in this regard is highly appreciated.
Anuj
