What data Flow should be chosen for Calibration
I have built the model in waterGEMS.
I am having flow and pressure data at the inlets of the DMA and pressure data at the pressure loggers points within DMA.
I have a question regarding utilizing the flow data:
I have flow data with 5 minutes interval for all days. Its for various months.
How should I use this flow data?
Do I have to use the flow data for a single day? i.e. for 24 hrs simulation, and if yes, which day should I select, as the data varies.
Shall I select the day having highest flow, or the day having average flow ?
Please guide on this.
Thanks.
