1- The pipe below (channel) in the model attached is showing Hydraulic Jump, can provide justification why that happened? and is there any enhancement to be done?
2- I have noticed that if the backwater analysis change to capacity analysis in the calculation option it will change the profile view, can please elaborate on that?
Mohamad Azzam
Hydraulic Jump.7z
Hello Mohamad,
Hydraulic jumps are possible with a gradually varied flow calculation. It is most common with steep slopes, but there can be flow discontinuities that can occur in models based on this. The following link has some useful information: Hydraulic grade discontinuity at steep pipes or across nodes (frontwater analysis).
Changing to Capacity Analysis can impact what the profile looks like. This link has more information on this: Backwater Analysis vs Capacity Analysis flow profile methods.
Scott
Dear Scott,
Thank you for the links provided. explained well.
The same example if you model it in SWMM engine the hydraulic jump will disappear, correct me if I am wrong? if yes; what do you consider in reality, is the Hydraulic jump will exist or not? I know both are different engines and methodologies and the question about the reality.
Mohamad.
The hydraulic jump looks correct to me. The smaller size conduit downstream is causing a tailwater condition on the pipe in question. The flow in the pipe appears to be supercritical, and is transitioning from critical depth to normal depth (S2 forewater curve) when it meets the higher tailwater. Thus, a hydraulic jump.
Karl Dauber, PEAdvance ConsultingLaurens County, SCkarldauber@advconsult.netwww.advconsult.netwww.linkedin.com/in/karldauber
