Ask with the Structure drop option
Good morning Bentley teacher
I am designing a sanitary sewer and I have doubts regarding the drop chamber.
In the options of Default Design Contrainst-Node = There is the option for the program to create these fall
chambers when there is a difference between the starting pan elevation and the final pan elevation. But I am not applying this design parameter that I am making, this is because I have too high slopes and I require these chambers.
attached model
Prueba de camaras.rar
