I have noticed the following two cases in the SewerGEMS Regarding volume:
Case 1:
The total reported system outflow volume in the calculation summary is not matching the summation of the volume out at the outfalls as marked in the screenshot below
Case2:
The Statistic "Sum" Volume (total runoff) is not equal to the total runoff for the whole catchments (when I copy to excel and do summation), also comparing to the total Inflow in the calculation summary.
From Statistic and calculation summary = 9,927.7 m3
From Excel = 9936.8 m3
The model is uploaded to the secured link, please check scenario "DM 10YR 1440MIN"
Hello Mohamad,
For Case1, a timestep of 0.5 minutes gave me the total volume as 9919.8 m3 in Calculation Summary and 9919.6 m3 from the sum of both outfalls. A smaller timestep can help you in this case to get both the values same or very close to each other.
See this article for troubleshooting Implicit Solver results: Troubleshooting unstable SewerGEMS and CivilStorm results using the implicit solver
For Case2, I kept the timestep as 0.5 minutes only and the results match in this case too. The total runoff from the catchments by copying the runoff column and adding up the volume in Excel gives a sum of 9927.65 m3 and the Statistics show the sum as 9927.66 m3. With an improved timestep and higher display precision (2 in this case) the results would match up. See this article for increasing display precision: Changing the display precision (decimal places) or format for an attribute
Hope this helps.
Yashodhan Joshi
Answer Verified By: Mohamad Azzam
Hello Yashodhan,
That works, and I did check the Troubleshooting post.
after that change in the calculation option, I Run the scenario "DM 5YR 1440 MIN" the Total Inflow volume is Less than the Total system Outflow Volume, is that possible?
Mohamad
The continuity error for the model is actually around 0.026 % which is a good value for a stable solution. If you follow the troubleshooting steps for Implicit Solver provided here, you can get a more stable solution. However, to really understand if your model is giving good results please compare them to field observations under similar conditions.
I tried with a "warm start" and was able to get an inflow of 6417.3 m3 and outflow of 6418.7 m3 which are close.
The above screen shot from Eng. Azzam shows that the continuity error is 0%, then how there is difference between inflow & outflow volume.
Also if there is continuity error then outflow volume should be slightly lesser than the inflow volume - please explain.
Ganesh Bala S
Design Engineer
Khatib&Alami Engineering Consultants Pvt. Ltd.
Ganesh,
When rounding to one decimal place, the mass balance error can still be 0.0% while the inflow and outflow volume (no overflow or volume change in this case) can still be slightly off. This article explains how the continuity error (CE) is calculated. In this case:
CE = (6417.3 - 6419.0 - 0.0 - 0.0) / 6417.3CE = -1.7 / 6417.3CE = -0.0002649 (-0.026%, rounding to 0.0%)
The slight differences seen in this particular modeling case indicate that the results are quite stable and well within the typical range of what would be acceptable, especially considering the margin of uncertainty with many other physical parameters and with the actual built system.
