Tentei gerar uma simulação de de um projeto que estava no sewergems no openflows flood, na hora de iniciar a simulação aparece a mensagem de erro:Data File does not exists :...\data\Model_1.dat, eu verifiquei, e esse model_.dat está na pasta correta, alguém conseguiria me ajudar a resolver esse erro?
Hello Lucas,
I can see Model_1.dat is open on the right side. Did you "save" this file after editing? Can you save and close all the open files to the right before running the simulation?
Maybe the edits aren't saved before running the simulation.
Let me know if by saving and closing the Model_1.dat you are able to run the simulation.
Yashodhan Joshi
I believe the problem is the related with the path of the folder where the model was created. It contains "Á" in "Área de Trabalho". OpenFlows FLOOD does not support this type of characters. In the same workspace please create a new domain and save it in a folder with no special characters "e.g. C:\FLOOD\UrbanFlood\". Create a new simulation in the new domain. Then use the "Copy simulation" tool to copy the simulation that does not run to the new simulation. Then select the "General Data" folder of the domain that does not run and copy the contents of that folder to the new domain "General Data" folder. Finally, go to the new domain properties and set the path to the digital terrain model, Grid Data file. You can then remove the domain that does not run from the workspace, selecting it and pressing the menu button Domain -> Remove.
Run the new simulation and everything should be OK. If not please let us know.
Kind regards,Luis
