Hi everyone
In HAMMER, I have created an ESP scenario but I have these 2 problems:
1- I can not find the Time Browser on the main screen og the HAMMER
2- There is no result in the Quality part og the result, for example Age, Quality and so on. Alle of them have N/A sign.
Please help me with these 2 above mentioned issue.
Thanks a lot in advance.
Br,
Hasan
Hello Hasan,
HAMMER does not include the Time Browser. While you can run an EPS run when computing the initial conditions, this is mainly used if there is a specific file you want to start your transient run. More information on doing that can be found here: How to set initial start time for a transient run in HAMMER.
HAMMER does not compute a water quality analysis. The primary reason for this is that a typical transient simulation, which is on the order of minutes, is not typically enough time for water quality to change substantially. See here for details: Water quality analysis during transient events. If you need to run a water quality analysis, you will want to use WaterCAD or WaterGEMS.
If you want to view your transients, you will want to use the Transient Results Viewer. You can view profiles animations and time history graphs at nodes in the model using the tool.
Scott
Answer Verified By: Hasan Meihami
Thansk a lot scott. Very helpful.
