I have been asked to produce drainage calculations for my stormcad model. The model includes catchment areas so Q=CiA and catch basins horizontal layouts to calculate spread, capture, and bypass flows. Does anyone have a report, workflow, or idea on how I can create such a report? StormCAD Connect
Thanks.
Hello Brian,
You can directly get the runoff from every catchment in StormCAD after analysis. If you need this information in a report you can generate the catchment report under Report > Gravity Tables. You can also simply copy the catchment flextable and paste into your report if that's what you are looking for.
For catch-basins, you can get the spread, captured flow and bypassed flows by adding these columns in the catch-basin flextable. See the below article for customizing the flextables to getting necessary result data;
Customizing FlexTables for viewing and reporting data
You can also look at creating a custom report right out of StormCAD in which you can choose which tables, graphs, profiles can be included in your report. See this article which has details about this: Creating Custom Reports
Hope this helps.
Yashodhan Joshi
To add to Yashodhan's answer - since you're specifically looking for a report on catchment calculations (and maybe not the overall flow), I would recommend including fields in your Flextable or custom report like these (assuming you only have Rational flows from catchments):
