Hello:Is there a way I can get the validation data for Watergems? Like any of the manual calcs or comparisons with the other software? Or test case data?Thank you,Yusuf
Hello Yusuf,
The following article is the extent of what we have to address the topic of validation/verification: Validation or Certification documents for Hydraulics and Hydrology products
Internally at Bentley, we have a suite of test models whose calculated results are compared between new versions to ensure that results are compatible. These are not publicly available. You can see mention of this in the document referenced in the above article called "Bentley Software Development Methodology".
Is the certificate still valid for later versions?
Yes, the information and documents referenced in the wiki article are still applicable to the latest releases.
