Hello, I am using StormCAD within OpenRoads. I am working on creating an existing model and some of the depths are less than ideal (not at minimums currently required). The problem I am experiencing is when I set the invert elevation sometimes the invert elevation automatically changes to an apparent minimum depth. I have looked in the catalog that I am using and cannot see a minimum depth. What property/where can I change so that I can set the inverts as they currently are?
Hello Damien,
What are the settings for the conduit properties "Set Invert to Start" and "Set Invert to Stop"? If these are set to True and you change the invert elevation on the manhole or catch basin the conduit is connected to, the conduit start and stop invert elevation will change as well. If you do not want to use the same invert elevation for the conduit as the end node, set these fields to False and you will be able to set the invert elevation manually.
Otherwise, if you are modeling a Design run in StormCAD, the invert elevations can change depending on the design settings. If you run an Analysis calculation, the invert elevations will not change.
If this doesn't help, more details about what data is changing and when it is changing may be needed.
Scott
Hi Scott,
Thanks for following up. I have set design options for structures and pipe inverts to false. I am trying to run an analysis model as its an existing conditions model. When I type in the surveyed invert (612.27) in the highlighted field below, it automatically changes to 611.44. I have tried setting "Set Rim to Ground Elevation?" to false as well but that doesn't change the behavior. I suspect it has something to do with a rule regarding the inlet in the inlet catalog; however, when I reviewed the catalog I could not find a parameter for minimum depth.
Cheers,Damien
Damien, I suspect this issue may be related to something specific to OpenRoads Designer (ORD). Which version of ORD are you using?
Do you have access to a license of StormCAD (outside of ORD) to test if the same issue occurs there? (you can open the DGN file from the File Open dialog).
Hi Jesse,
I am using ORD CE -2021 Release 1 Update 10 (Ver. 10.10.01.03). I found the location of the model in ORD (C:\Users\ddivittorio\AppData\Local\Temp\Bentley\SUDA) but when I renamed and tried to open in StormCAD it asked about the missing SQLlite database. Do you know where ORD saves this? So I can open the same model in a standalone StormCAD?
Damien, the StormCAD model is stored inside the DGN file. In the File Open dialog in StormCAD, choose "DGN" from the "Files of Type" dropdown and select the DGN file associated with your ORD project. See: Opening a DGN file containing OpenRoads Designer drainage data
If you can reproduce the problem in StormCAD, please send us a copy of the DGN with steps to reproduce: Sharing Hydraulic Model Files on the OpenFlows Forum
