Hello, I am using StormCAD within OpenRoads. I am working on creating an existing model and some of the depths are less than ideal (not at minimums currently required). The problem I am experiencing is when I set the invert elevation sometimes the invert elevation automatically changes to an apparent minimum depth. I have looked in the catalog that I am using and cannot see a minimum depth. What property/where can I change so that I can set the inverts as they currently are?
Hi Jesse,
So, I was able to change the invert opening the model in StormCAD; however, I changed the invert saved and opened the DGN in ORD and synchronized the utility data and the invert changed back to the incorrect value. Any suggestions on how to work around this in ORD? Thanks for your help!
Cheers,Damien
Thanks for testing that. It appears to be an issue (or perhaps working as designed, somehow) with OpenRoads Designer, which is handled by our Civil team via the OpenRoads forum. I am going to contact a few of my colleagues from that team to assist with this. Thank you for your patience.
In the meantime, are you able to share the DGN file (see link in previous reply) in case the problem is project-specific?
Thank you Jesse! I have uploaded the file using the confidential method. I look forward to learning more about this issue and how to resolve it.
Thanks, I see it. Are there are particular steps to reproduce that would help our Civil team diagnose this?
I just change the invert of C-5.1.1 to anything above 611.44 and it changes back to 611.44. There are a few others with similar issue but I assume resolve one I will be able to resolve all using same methodology.
