I am setting up a stormcad model. When I start drawing the catchment areas, stormcad locks up, stops operating and terminates the program. Has anyone else had this problem. If so, what was your solution?
Rick,
I'm running StormCAD version 10.03.04.53 integrated with MicroStation CE Update 16 version 10.16.00.80 and I am able to place a Catchment without locking up. What versions of MicroStation and StormCAD are you using?
Thank-you,Larry
I also just realized that only one version of StormCAD supports integration with MicroStation CE, but there are 2 versions of MicroStation CE available. Which version of MicroStation are you using?
Sorry for any confusion,Larry
Also, does this happen only in one model or any model? And are there any special steps that you took that I should be aware of?
I'm running the same versions as you. However, I just realized that it is running in trial version as I just got it through Virtuosity. I'm going to get it checked out and see if that fixes the problem. I have not tried running it on any other models.
Larry, I have registered the product and tested a different model. On the different model, Stormcad still locks up when trying create a catchment area
