I ran my simulation but is giving me error message that pipe is very smooth, C >=170 or DWf =0. How do I solve the problem please.
Hello Abubakar,
Can you share a screenshot of the error you are seeing? Are there any other user notifications - maybe share a screenshot of those too?
Awaiting your response.
Yashodhan Joshi
I assume you are using HAMMER and encountering a friction factor error. HAMMER calculates a Darcy-Weisbach friction factor for each pipe (to use with the transient numerical solver) based on the difference in hydraulic grade across each pipe. Most likely the headloss is too low in the pipe in question, causing the headloss to be zero and the friction factor to be calculated as zero. You can read more about this situation and what to do in the following related articles:
What equation does HAMMER use to compute the Darcy-Weisbach friction factor (f)?
User Notification: "There is an error in the data for this pipe. The associated data is incorrect"
