Dear Bentley,
Is there any way to change the fluid property (i.e. Bulk Modulus) in Hammer?
I found a solution in forum in 2015 which said it's under calculation options - hydraulic, but my software doesn't show the same thing
Modeling other fluids or fluid temperatures - OpenFlows | Hydraulics and Hydrology Wiki - OpenFlows | Hydraulics and Hydrology - Bentley Communities
BTW I use academic license. My calculation option window is attached.
Shiqing
To add to Yashodhan's answer - the bulk modulus impacts pipe wave speed if using the wave speed calculator tool. This tool enables you to select from the liquid engineering library where the bulk modulus and other liquid properties are stored. See more here: Entering Pipe Wave Speed for a Transient Simulation
