I am using "Bentley OpenFlows CivilStorm® CONNECT Edition Update 3". I am looking for detail design reports for links like channels, conduits and gutter. where could i get the same?
Hello Pravin,
You can create reports from the element flextables. This link has information on formatting the flextable to display the properties you want to have in the report: Customizing FlexTables for viewing and reporting data. You can also include flextables in custom reports: Creating Custom Reports. There are also some inventory reports in the Report tab in the CivilStorm ribbon.
If that doesn't help, more information on what you are looking for may be needed.
Scott
Scoot,
Thanks for your reply.
Actually I am looking for formulas against each answer.
where or can i see formulas used for those particular calculations? Client is looking for detailed report and not just answers/numbers.
You can find common formulae used in calculations in the help documentation. CivilStorm > File > Help > CivilStorm Help. However you will not get formula used for each and every answer. For each of the result field description is mentioned at the bottom about how the results are derived
We will check internally if any such document is available which can be shared with you.
Sushma Choure
Bentley Technical Suppport
