I have a model including two main line at east and west side of a pumping station. I have included two Hydropneumatic Tanks at west and east side. The problem is that for the tank in the west side, the gas volume is increasing no matter how the size is (figure below). If we put 2000 L as the size of the Tank, the gas volume is more than 2000 and if the tank size is changed to 5000L, the gas volume would be 5000 L (as increasing line) and so on. For the east side , the gas volume increases to the tank size and then decreases, if we put 20000L as the tank size the maximum gas volume will be 20000 and if we change the size to 50000 the maximum gas volume would be 50000L and so on.
Could you help me to find out the issue?
Hello Vali,
Try and use a value like 10 for Report Period (Transient) in the Transient Calculation Options. See if this helps with the linear increase of gas volume. See this article which provides more details on this: Hydropneumatic tank Extended Node Data graph shows linear continuous increase
Let me know if this helps.
Yashodhan Joshi
Thanks Yashodhan, it worked. But, another issue that I have explained earlier is to exceed the gas volume from the tank volume. If I choose the tank volume 2000L, the maximum gas volume is computed around 22000 L and If I choose 22000 L for tank volume the maximum gas volume is calculated 50000 L? The screenshot below. Do you have any solution for this? Thanks
Are you seeing any user notifications related to the hydropneumatic tank? If so, information on these may be useful. Otherwise, I would recommend reviewing this wiki with general information on hydropneumatic tanks: Modeling Reference - Hydropneumatic Tanks. This includes information that may be useful for what you are seeing. Overall a change to the properties of the tank will impact the results. A bigger tank will allow for a greater gas volume. Overall, you would general size the tank so that it does not become empty.
To add to Scott's response -
Many thanks Scott and Jesse for the reply,I have reviewed all the notes that Jesse pointed out. They are very helpful and I could fix some issues before reaching you out. All is appreciated. The issue that I have is the hydropneumatic tank always drains eventually no matter how large I make it, as stated before. Just for information, I am modelling pump shut down-start up, that is all pumps are shutting down after 10 s and then remain off for 200 s, after that they start up. I first used the 100 s simulation to just simulate pump shut down for some sensitivity analysis. The Tanks has a bladder and is at a high point as there is no other location for the tank (according to animating results). The pipe profile is very undulations. Below are some results.
As we see, while we increase the size of the tank, the maximum gas increases. And when we change the preset pressure, the volume is significantly increases. I did also change the orifice diameter and losses but I got the same results.
I also did the simulation with the 1000 s time for pump shut down and start up. Below is the results, as we see the maximum gas volume is larger than tank volume.
Your advise is much appreciated!
