I am trying to print to Bluebeam PDF profile and when I use print preview to switch the paper size to 11X17 WaterCAD crashes (version 10.03.01.08).
Not sure what to do about that.
Nastassja
Nastassja, this may be difficult to troubleshoot as I do not believe we have access to test this.
Some initial questions for you:
What's new in WaterGEMS and WaterCAD CONNECT Edition Update 3.2 (10.03.02.75)
What's new in WaterGEMS and WaterCAD CONNECT Edition Update 3.3 (10.03.03.72)
What's new in WaterGEMS and WaterCAD CONNECT Edition Update 3.4 (10.03.04.05)
What's new in WaterGEMS and WaterCAD CONNECT Edition Update 3.5 (10.03.05.0X)
Nastassja - I would suspect a problem with the Bluebeam pdf driver. I have used several different pdf applications (including Adobe and Foxit) and have never had a problem with changing paper size. I've never used Bluebeam so have no experience with it.
Jesse,
My responses are below
Gary,
I could not get it to work with any of the PDF print options. See the list of options below:
I do not have any other PDF readers on my computer. I downloaded Adobe Acrobat, but it is not showing up in my lest of print options. I did restart the program as well.
You have a very interesting problem. I have used MS Print to PDF sparingly, and none of the others on your list. My only suggestion would be to try a 3rd party pdf writer (I've had tremendous luck with PDF995 in the past, as well as Foxit).
Regarding Acrobat, when you run the installer it should ask you if you want to add it to your printer list.
