你好,在HAMMER中,瞬时摩擦力计算方法包括恒稳态、准恒稳态、非恒稳态与非恒稳态-vitkovsky四种类型,这四种计算方法存在什么区别?
Hello Shoujun,
HAMMER enables the user to use one of four friction methods including steady, quasi-steady, unsteady and unsteady-vitkovsky. The unsteady friction methods tend to be the most accurate.
You can find detailed information about these 4 friction methods in the help documentation.
In addition below wiki explains differences between "Unsteady" vs. "Unsteady - Vitkovsky" transient friction methods, please go through it.
"Unsteady" vs. "Unsteady - Vitkovsky" transient friction methods in HAMMER
Google Translation
寿君,您好
HAMMER 使用户能够使用四种摩擦方法中的一种,包括稳态、准稳态、非稳态和非稳态-vitkovsky。非定常摩擦法往往是最准确的。
您可以在帮助文档中找到有关这 4 种摩擦方法的详细信息。
另外下面的wiki解释了“不稳定”与“不稳定-维特科夫斯基”瞬态摩擦方法之间的区别,请仔细阅读。HAMMER 中的“不稳定”与“不稳定 - Vitkovsky”瞬态摩擦方法
Sushma Choure
Bentley Technical Suppport
你好,请问一下在这四种方法里面,它们哪些考虑了流体惯性与系统弹性?或者只考虑了其中一种。谢谢
Are you able to converse in English? I see that you have also posted on the ChinaFirst forum here.
I have updated the following article with more details on when each method is typically used and why, along with a copy of the details in the Help documentation explaining how each method calculates the friction factor: Understanding the Transient Friction Methods in HAMMER
我已经更新了以下文章,详细说明了每种方法的使用时间和原因,以及帮助文档中解释每种方法如何计算摩擦系数的详细信息副本:Understanding the Transient Friction Methods in HAMMER
