Not sure how this happened. I saved my project yesterday and today there are two files, The original as I named it and a second one with my as Notebook ID Name
The original seemed to be saved some time ago which is not true. I saved it yesterday.
The one with the additional naming was saved when I saved last night but the thing is it gives me the error below
How can I resolve this?
Rossouw Boshoff
Hello Rossouw,
The error message means that database file of this model is not found in that folder. Model cannot be opened without database file.
Please look for .wtg.sqlite file and copy it in the model folder, then the error will not appear. However database file will not be moved unless you copied .wtg files only to a new folder which appears from your first screenshot of 2 models.
Warning message "…sqlite not found" when opening a model
Are the model files saved on network drive?
Sushma Choure
Bentley Technical Suppport
This happened to me a few times, the problem seems to occur during one-drive synchronization (I see you're using one-drive from your screenshots). It looks like the .wtg file experienced a synchronization error leading to the .wtg file you saved yesterday being renamed with your laptop name appended. The error most likely did not occur with the .sqlite file, which is why that does not have your laptop name attached. Because the correct .wtg and .sqlite file now have different names, they cannot "find" each other.
Make a backup of the .wtg file without your laptop name attached (rename it to append -old for example), and then rename the newer file (with the laptop name attached) by removing your laptop name from its name so the part before the dot is the same as the .sqlite file.
Answer Verified By: Rossouw Boshoff
Joeri you are a champ! Thats exactly what happened. Onedrive created the problem due to sync issues. IT sorted out the onedrive issue. Your suggestion for Watergems files worked perfectly.
We have incorporated information provided by Joeri in an existing wiki.
