Hi,How to decide surge tank height in Hammer analysis ?If we supply water from one reservoir to other reservoir.Is there any profile available in hammer to view surge tank water level?
Hello Absar,
There isn't any specific guidance for determining the size of the surge tank. If you want the surge tank sized so it doesn't overtop, you can try different settings in the calculation. One thing to keep in mind is that properties like ratio of losses and other surge tank properties can impact the results as well, so you will want to consider these settings as well.
I would recommend reviewing the surge tank modeling reference for more information on surge tanks: Modeling Reference - Surge Tanks.
Scott
To add to Scott's answer -
