Hammer results File doesn't contain any transient extended node.
Hi, I am new to Bentley Hammer. I am analyzing a Gravity pipeline where water will run from 1619 m elevation to 1400 m elevation in a hilly area with ups and downs. When I check " Transient Results Viewer" it gives a dialogue box.
"The hammer results file doesn't contain any transient extended node data. Extended node data is only available for certain pumps, turbines and hydropenumatic tanks".
Why am I seeing this notification? Does this mean this gravity pipeline does not face any pressure vapour surges, vapour volumes etc. or is it some error in my drawing of the  profile.
Parents Reply Children
