I was trying to download dataset files for "Water Distribution Design and Modeling Advanced using WaterGEMS CONNECT Edition" from Learn server but I'm getting the folowing error.
http://cdnllnw.bentley.com/s/p/ld/WaterDistributionDesignAndModelingDataset-US-ALL.zip?s=1635505690&e=1635548890&h=142aafd514f0b5e9488a3cdd1fe06dbd
Thanks for any help.
There could be some issues with dataset, need to check if it is available to download, please allow us some time to check it internally.
Sushma Choure
Bentley Technical Suppport
Sure. Thanks for your reply. Will wait till it is fixed.
Nilanjan Choudhury,
I have a copy of the Dataset that I have uploaded to our Sharefile server here.
Please let me know if you have any trouble downloading it from this location.
Thank-you,Larry
Answer Verified By: Nilanjan Choudhury
Thanks a lot Larry. That helped a lot. Cheers.
See also (linked to from the YouTube channel version of this training course): Water Advanced CONNECT Edition Workshop Dataset
