ref: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/219654/stormcad-for-microstation-connect-edition/
Jesse,
I now have a new issue. i have downloaded & installed the latest version of Microstation. Earlier this week this message started coming up when i start Microstation and it will not let me into Microstation. Help!!
Rick, see the following article which mentions the error: Troubleshooting MicroStation integration
After upgrading MicroStation, you will need to re-run the Integrator (the shortcut in your Start menu called "Integrate StormCAD with...".)
